Can sweep protrusion stop at surface?
ptc-267878
wildfire 4
I created a sweep protrusion (as seen in attached image) and would like it to stop at a surface. Right now, it just passes through the surface and stops when it has reached the end of its trajectory. If you have suggestions, please let me know.
5 REPLIES 5
You could copy a surface of the protrusion and use it to either merge or trim the sweep surface. It adds two features , the copy and the trim or merge, but it would give you the result you're looking for.
Tim
KrisR
(To:ptc-267878)
Can you stop your trajectory at the surface with a relation or parameter?
and then the "merge ends" option may work
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
Create it as a sweep surface, then merge it to the surface you want it
to stop at.
Here is a quick video on my new Youtube Channel that shows one of many methods of doing this.
Hope it helps
http://youtu.be/d4ZAQQW-Pn8?hd=1
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
