Can't change tolerance mode
ptc-2803703
Good morning,
In my drawing, for a created dimension, I cannot change the tolerance, mode to enter a ± tolerance. I have looked through past threads add tried several things others have posted on this topic. In my config file, I have set
1. tol_display = yes
2. tol_mode= limits
3. tbl_driven_tol_val_edit = yes.
I am using WF4, M220 if thay matters.
Thanks, Bert
Bert,
There are also options in the Drawing Options file that need to be set in addition to the configuration file options. Not sure you set them in both or not...
-marc
Bret,
Yes there is a setting in the Drawing Options to show tolerances. - tol_display - yes
Mark Peterson
Design Engineer
Varel International
That was it. Thanks.
