Can't change tolerance mode
davehaigh
I just noticed this morning that the tolerance mode is grayed out on my model dimensions.
I created a new part starting with "Empty". No template part. Same behavior. This is new to me.
Any ideas what's up?
Config option?
WF4 - m170
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Sounds like you are setup to use tolerance tables, and the config option “tbl_driven_tol_val_edit” is set to “no”.
BenLoosli
(To:davehaigh)
Look at your setting for tol_display in config.pro. If set to YES, then I can change the dimension property tolerance mode.
Thank you,
Ben H. Loosli
USEC, INC.
