I'm pretty new to Creo and was modeling a birdcage. I'm not really sure when this happened but the surface lines all dissappeared and look clear while the hidden lines are the only thing that show.
I've been trying to find how to reverse this process but can only find topics regarding hidden line properties within a drawing.
Any help would be appreciated.
A picture of the problem is attached.
Alright, well, not sure if I changed or not but the problem just went away. It was happening to that one part for a few days now.
I decided to reassemble my birdcage, just in case it was something I messed up in Assembly, opened the part into the new assembly. Gave up immediately and closed it out. Then the part was loaded in the active window fixed.
Magic.
Magic.
