Can't show model annotations in Parametric 2.0
srizvi
Hello everyone.
I'm new to using Parametric. I randomly start having issues.
I was annotating my drawing. So I would right click a view where I want the annotation and than I would click Show Model Annotations. So when I was doing the for several minutes I could access all the annotations. However, now when I do it I don't see any annotation. The message is displayed that I should select a view to show the annotations. So I select the view but still nothing.
What could be going wrong here?
dschenken
(To:srizvi)
If you showed a model annotation and then 'Erased' the annotation, PTC has taken that as a signal to hide the annotation. You need to 'Delete' a shown annotation to show it somewhere else. What PTC is referring to with 'Delete' is to delete the link between the view and the annotation. What they meant by 'Erase' is anyone's guess. However, if you delete a drawing annotation, it is deleted from the drawing.
You can look at the drawing tree to see the view list and then expand the views to see which ones have annotations. Pick the ones that are hidden and select Delete. You will be able to Show those annotations in other views.
1 REPLY 1
dschenken
(To:srizvi)
