I've done this in models, but in the part drawing when I add a drawing view, the view states dialog box is grayed out for simplified representation.
You can add model Drawing Model > Set/Add rep > Select Rep and create view of part.
Just to elaborate on what @Mahesh_Sharma said, part drawings treat simplified reps. as separate models. You can't take an existing view on a part drawing and switch it to a different rep. (like you can with assemblies.) Instead you have to first add the part to the drawing again, choosing the rep. when you add it, and then create a new view with that part (rep.) set as the active model.
