Cannot export to Adobe Acrobat (.pdf) or AutoCAD
ptc-3170917
Pls help me fix this problem. I have received warning When I export data to Adobe Acrobat or AutoCAD: "The system is running short of memory. Continuing this operation may cause the session to terminal. It is recommended that you save you work as soon as posible. Click OK to continue this operation or Cancel to abandon it" Thanks.
5 REPLIES 5
mhanak2
6-Contributor
(To:ptc-3170917)
Hi Martin, Thanks your help! i have checked as you said(Total memory: 2GB; Used: 1.3GB; Xtop.exe: 820 MB). I added more 2GB RAM memory to that computer but the same problem. Beside, Other computer is working normaly and only 2GB memory.
Martin Hanák
JerseyC
6-Contributor
(To:MartinHanak)
I have similar problems, when xtop.exe is over 1,2GB WF5_M30 is on the way to hell. System winXP_32 bit 4GB RAM, 3GB switch in boot.ini.
mhanak2
6-Contributor
(To:JerseyC)
"Jiri Cakl" wrote:
I have similar problems, when xtop.exe is over 1,2GB WF5_M30 is on the way to *beep*. System winXP_32 bit 4GB RAM, 3GB switch in boot.ini.
