Cant select axis for exploded view lines.
ptc-5463883
I am trying to select the axis of parts in an exploded assembly. They are visible, but I can not select them to use as references. It only lets me select the outer faces of objects. I am using Crea Elements/Pro Schools Edition which was given by my university. The project is the Pulley Support Assembly.
Thanks.
1 REPLY 1
It is not about the version. same issue will occure in creo 2.0 also. Actually the axis only used for representation of exploded parts. you can select the axis on features parameter, but you cannot take reference these axis.
