Has anyone a method of modeling a Sandvik Capto shank? This is now an ISO standard 26623, and looks kind of like a Wankel rotor. TIA
Peter, My equation was just meant to be a rough stab at the shape; I still don't have the proper info. Couldn't make sense of your link in the earlier post as far as accessing what we need here, and the image you sent in the later post doesn't show. You must have been trying to give me the info,
"Peter Brown" wrote:
Tim, True - the Mazda rotary engine uses a Reuleaux triangle. The Capto, while sort of similar, is a polygon curve. I only described it as such because it was easier to convey since the Mazda is more widely known. Regards
The Reuleaux triangle is comprised of 3 constant-radius arcs - you could draw one with a compass. The Capto is a polygon curve where the radius is constantly changing along each of the 3 lobes. Pete ps.
