Central Model Library - Creo Parametric
Daves1
I would think that this has to be possible....
I have created a 'model library' of many of our components. When I create an assembly using these components, I need to copy the components to the same folder where the assemblies and drawings are saved, otherwise when I open them the components fail to load.
Is there a setting somewhere that can tell Creo Parametric to look for components in a specific folder rather than the current folder, so that they all don't need to be in the same location?
This would make life much easier!
Thanks in advance for any insight you all may have on this!
- Dave
BrianMartin
(To:Daves1)
Hi Dave...
Yes, this is possible. You're looking for search paths. This feature gives you the ability to specify a list of directories Creo should check for components. If you load an assembly and a necessary component isn't located in the current working directory, Creo will start running through the search paths to find the missing model.
To specify a search path, you can either add one new line to your Creo configuration file for each new folder you wish to search or you can add one single line to your configuration file that references a separate text file containing many lines.
Technique #1: Add individual lines for each folder
(1) Go to File->Options->Configuration Editor.
(2) Click Add
(3) Type search_path into the option name field of the window that appears (as shown below)
(4) Enter the folder you wish to search in the option value field.
(5) Select OK to add the search path. Repeat this process for each new folder.
Technique #2: Add one line to the config file and reference an external list
(2) Click Add
(3) Type search_path_file into the option name field of the window that appears (as shown below)
(4) Enter the pathname to a search path file into the option value field.
(5) Select OK to add the search path file pointer.
(6)Create/Edit the search path file listing as a text file. A sample text file showing the way to set up a search path file is attached to this message.
Make sure the pathname to the search file you set in Step #4 is correct or Creo won't read your search paths! Consult the help files for search paths for more information.
Let me know if you have any trouble!
Thanks!
-Brian
7 REPLIES 7
BrianMartin
(To:Daves1)
Hi Dave...
(2) Click Add
(2) Click Add
Thanks!
-Brian
Wow! I can't thank you enough Brian!
You've just made my life a whole lot easier!
- Dave
BrianMartin
(To:Daves1)
Always happy to help!
Write back if you get stuck in any way.
Take care...
-Brian
Bari
(To:Daves1)
Sorry for entering this discussion but maybe you find this Product idea (http://communities.ptc.com/ideas/1581) useful. It will allow another approach to the use of search_paths.
Thanks.
I have a similiar issue, but I want to force Creo to save the components that I assemble from a library folder, into the working directory. Do you know how I can do this?
Ana
I guess you could use the "Backup" function in Creo...
spete
(To:Daves1)
Try setting the config.pro (or config.sup) option pro_library_dir.
This option "Sets the default directory for the Creo libraries (or any libraries you have built containing the proper index menu files)."
