Change Creo View Language
VeqTor
Hello forum,
I have already selected "German" in the Options at "Startup":
However, Creo View still starts in English all the time.
What do I do to change the UI language to "German"?
6 REPLIES 6
Sanath
(To:VeqTor)
@VeqTor, try to set the environment variable "PVIEW_LANG" to "de"and see if that makes any difference.
MartinHanak
(To:VeqTor)
@VeqTor wrote:
Hello forum,
see https://www.ptc.com/en/support/article/CS96862 document.
Martin Hanák
VeqTor
(To:MartinHanak)
Thanks -- I had seen these references already. However, I can't seem to locate where those Creo "environment variables" are to be found?
MartinHanak
(To:VeqTor)
PVIEW_LANG is defined in Windows.
See an example on https://docs.oracle.com/en/database/oracle/r-enterprise/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0 page.
Martin Hanák
VeqTor
(To:MartinHanak)
Thanks Martin,
I will have to ask my IT person for this, because I don't have Admin privileges to access those Windows system settings.
Best regards
vecTor
KenFarley
(To:VeqTor)
If you want to set an environment variable to run a program, you could prepend the setting to the current "Target" (I don't know what the German word for this would be, maybe Target?) on the shortcut you use to run Creo now.
Something like
"SET PVIEW_LANG=de";"C:\Program Files\PTC\Creo 4.0\M090\Parametric\Bin\parametric.exe"
You're basically just executing multiple commands, separated by semicolons.
You'll probably have to do some testing to get the nomenclature right, but that should work. Unless parametric.exe spawns off other processes that don't inherit the local environment variable you just set, then you are back to having to get your IT police involved.
