Change envelope shrinkwrap geomerty? - WF4
davehaigh
I want to remove a part from my envelope surface subset shrinkwrap. I don't see how to do this with the new interface in Wildfire 4.
In the past, wf2, I could do the following: View, Substitute, Envelope Manager, Edit, Redefine, Change Members, Done. Control click the item to remove from the envelope, pick ok, done and done again. Answer yes to update all simplified reps. At this point I was back in the envelope manager, I would then pick Edit, Redefine, Change, Geomerty, Confirm, Indicating I understand that this will affect other simpified reps. I would then expand the part in the model tree, pick on External Shrinkwrap id 1, Right mouse click and select Edit Definition. In the feature definition dialog pick Comp Subset, Define, By Envelope, OK, Done, OK. Move the Envelope Manager out of the way and pick Done in the menu it was hiding.
Not a pretty process, but at least I could change the envelope. How do you do this in WF4????
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
0 REPLIES 0
