Change multiple descriptions in a repeat region?
mjenkins
Does anyone have a good solution for this?
I have tried these methods attached:
I have been able to successfully multiple part names but only one description.
After adding, I change the table values to rpt.rel.name and rpt.rel.var
Found a great summary here in the archives:
http://portal.ptcuser.org/p/fo/st/topic=3&post=100753#p100753
Going to try out a few tips from Nicholas Ely's attached guide.
I modified my orignal code as follows and it works great!
The issue seems to be with nesting the statements and putting the VAR== after all the descriptions and the NAME== after all the names.
