I do not see a dedicated community for Cabling Corner. Can PTC add that? or where to look for if already there? Thanks!
Cabling is part of Routed System Design which is covered under 3D part and assembly design currently. Routed system design is the appropriate label for cabling/piping.
okay. Understood.
So piping also comes under Routed System Design? Sweeps, Trajectories, curves also can be used for routing, Are they in the same domain? I am ok to dig in Routed System Design, but it definitely should help me better find, be it: Routed System , Cabling specific. 🙂
Sweet! That Helps . Thx
