Can I write a relation for above col rep'd bom?
Wayne
do you want to change values for CABLE item, only ?
Which repeat region parameters are displayed on first four columns ?
Hi Martin,
Yes - just the cable for now.
In the columns the following were generated by rpt region col rep command:
-3 qty.m60r0
-4 qty.m64r0
-5 qty.m68r0
-6 qty.m2r0
Wayne
I have never seen something like qty.m60r0. I know for example &asm.mbr.name or &rpt.rel.myparam included in repeat region cell.
AND ... what it is included in 9th column ?
9th?
Those values are auto generated when using column rep I believe?
see my example and upload your pictures.
In my test drawing I have following repeat region table placed:
If I activate Table tab and click Switch Symbols command the I can see following repeat region table:
If I select cell in 2nd column, press right mouse button and click Properties command I can see following dialog box:
What information can you see in your drawing ?
I don't know if this is going to help.
I still do not understand qty.m60r0 entry. If you can please save repeat region table into .tbl file and upload it.
Martin,
qty.m60r0 initially is rpt.qty. when I mouse click it it reveals qty.m60r0. I don't get it either. Has something to do with the "column rep" initiation.
here is a .tbl and a .cvs.
Not sure if .tbl is any good without everything???
On a side note....I am using 2 boms. This one to break down different assembly configurations and another to show balloons. its such a cludge. But due to the inability for creo to show baloons in the colum rep version of the bome...this is what we all use as a work around.
I can only hope there is a better or 'right" way.
Thanks!
Wayne
I am sending you my test data. Open drw0001.drw and investigate table and its repeat region.
Martin,
Interesting. I need some time to analyze this. Looks like you create the bom using simplified reps of the assembly. Is Repeat Region Column Rep used?
Wayne
Yes, quantity columns belong to simplified reps and I used Repeat Region Column Rep command.
