Color Map Path
tgiauque
Color Map Path
One more "new computer" question - what is the config.pro option that lets you specify an appearance library file (.dmt) to load in WF5?
Tim
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
BenLoosli
(To:tgiauque)
pro_colormap_path
Specifies the directory path for a color map appearance (.dmt) file to be loaded from disk.
Use the full path name to avoid problems.
Thank you,
Ben H. Loosli
USEC, INC.
