Color Selector
ptc-3202400
Color Selector
How do I locate the selector, because I'm making a CAD for a school project and I need to make each component individual colors because they're side by side
At the bottom of the Part&Assy menu, expand the properties section. Select Part. Select the part you wish to modify (either from the viewport, or from the Structure Browser). In the Part Properties popup menu, open the Appear tab. There you can set the part color (among other things) Note that you can also create new colors from
