Color in an assembly
ChristianSmith
I'm using WF 4.0 and I've never seen this before. I have an assembly with many different parts which I'm color coding so that others can easily differentiate between the different parts of the assembly. I've always applied color in the part itself and not had a problem when I bring it into the assembly. All the parts are fine except one part that when looking at the individual part, the color is there. However, when I bring it into the assembly it doesn't show the applied color. Any ideas?
P.S. Dan, the only way I found this page was through my post in the other forum. For some reason the link doesn't work for me either.
Christian,
There is a possibility that the part in the assembly is colored at the assembly level and not the part level.
John
I wish it were that easy but that's not the case.
