Is it possible to set containers to a specific colour and linetype when by manage adding containders to a view? Instead of select manage-remove all-add container done, then selecting all geo change colour and linetype done and then again manage- add all done.
Changing colors of parts in Annotation has been made very difficult with how Creo changed the color command. I found this lisp program from Hilfeseite SolidDesigner and modified it some for our purposes.
I have included the command and instructions for the command. The tool will load into your commands menu under O-I Commands, By editing the header of the program, you can change this.
Regards
Tom
great!!
This works as I want but in a different way, I can only start the command by typing "Teilefarbe" in the user input line.
Is it possible to get a button in the toolbox menu?
