Conditional relations
sclamens
I would like to make a relation in a part to inhibate a fonction
thomething like this:
IF NBR_DOTS ==0
fontion is inibate
endif
Thanks for your help.
17 REPLIES 17
IF NBR_DOTS ==0
fontion is inibate
endif
I guess you want to suppress pattern of features. You cannot do this using relations. You have to use Pro/PROGRAM functionality.
See https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Fprogram%2Fabout_pro_program.html%23 section in Creo Help.
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/fundamentals%2Fprogram%2Fexample_a_parametric_design_for_a_blender_cover.html%23 show how to use IF condition to suppress specific feature.
Martin Hanák
Note: You can use https://translate.google.com/ page to translate text from French to English.
Martin Hanák
sclamens
(To:MartinHanak)
English is not a problem for me but it is with script. As I can see the tuto is for an assembly. I want to do this fonction on a part generated as a family. Then if I understand well what you told me it is not possible to do it.
I then going to think about a different clue.
the problem is that you did not explain in detail, what you're doing.
Martin Hanák
sclamens
(To:MartinHanak)
Not easy
I'm going to try to explain
I made 3 pictures that silulate the 3 configurations I want to do:
Buse_Config1 Nozzle with no dot
Buse_Config2 Nozzle with 1 dot
Buse_Config3 Nozzle with 2 or more dots
@sclamens wrote:
Not easy
unzip 2020-06-23_program.zip file.
mh.prt (created in Creo 4.0) contains PNT_QTY parameter. Set its value to 0, 1, 2 gradually, regenerate model and check model geometry.
mh_program.docx contains copy of Pro/PROGRAM included in model.
Martin Hanák
Here's a solution which uses a pattern (created in Creo 4.0)
It uses the same technique as MartinHanak, with an IF...END IF statement to suppress the pattern when there are no holes required.
You can change the values in the relations (at the top).
Just for fun I added something extra...maybe you want an octagon bolt in the future?
sclamens
(To:HamsterNL)
 Thanks for the example file but I can not open it 🤔
Which version of Creo do you have?
sclamens
(To:HamsterNL)
I have Creo 4.0.
Strange...if you are also on Creo 4, then you should be able to unzip the attachment and open the file.
Maybe you'll have to remove the "number file extension", so the filename ends with .prt ?
Dale_Rosema
(To:sclamens)
Just checking to see if you have an educational license of Creo. Non-educational licenses are not compatible.
I opened example.prt successfully (using commercial license).
Martin Hanák
sclamens
(To:MartinHanak)
I'm working in Bosch Compagny and for shure I'm using a comercial license.
Would it be possible to send the part unzip please.
See below the message I get when I try to open the prt
1.]
Are you able to open mh.prt from my 2020-06-23_program.zip file?
2.]
If you start your Creo you can see, that CAD-LINK application is started (in message area). I guess that this application checks every opened part ... if the part does not meet BOSCH criteria then CAD-LINK application disables Creo from opening the model.
Martin Hanák
sclamens
(To:MartinHanak)
Hi I managed to open the files. I was first unzip just the file but it did not work. I then unzip all at once and it worked.
That's great! Let us know if you have questions 🙂
Don't forget to mark one of the answers as the solution if it solved your problem!
