Anyone know of a Creo Parametric Config.pro setting that will allow Creo to display all file types when opening or when assembling a component in an assembly?
Working in a Multi Cad environment and need to assemble other CAD system files to Creo assemblies.
Don A
Looked through the list of config.pro options and there's no such parameter to set. But, as an alternative, you could define a mapkey to perform the steps necessary to get you to the point of selecting the file, but with "All Files" as the type specification.
See the following Product Idea to have this functionality added!
https://community.ptc.com/t5/Creo-Parametric-Ideas/Change-file-open-default-file-type-drop-down-filter-to-add-stp/idi-p/463722?search-action-id=68283231976&search-result-uid=463722
