I am controlling a component pattern in an assembly in Pro Program with a statement such as -
If Pattern_table:fid_2250="4_ejector_pins"
When the option of not having those components in the assembly is created in relations If Pattern_table:fid_2250="no_ejector_pins", the cut features made by those components in additional components in the assembly fail due to the components not being there.
Can these surface cuts in the assembly parts be suppressed by a statement in relations or pro program when the component pattern is removed?
thank you.
