I have a very simple cylindrical part. I want to control the diameter of this using a parameter called "DV_DIA" Whilst this should be straight forward, I am getting a little confused! At first I thought that the dimension controlling this diameter was "d7" therefore I entered d7=DV_DIA, but in the sketch view this dimension has the name "sd0" so should I enter sd0=DV_DIA? Is there two dimensions controlling one diameter?
