Convert .PRT to .STP Massive data
Ed13
8-Gravel
Hello all,
I have 256 units of ".prt" files from many ".asm" and i want to convert into .stp files. Anyone knows how can i do on a fast way?
Thanks in advance.
StephenW
(To:Ed13)
When you save an assembly to .stp, it keeps all the part files as individual models. Maybe I am misunderstanding the question.
If you have multiple assemblies, you could put them all in one assembly and export to .stp
You may want to look in to "distributed batch" which I think will help you do a conversion of many files. I have never used it but I think it may be your answer.
DavidBigelow
(To:Ed13)
You can use CREOSON to get that done pretty easily ... couple of options... JavaScript (you can modify the Playground help page) or use CREOPYSON (python library for CRESON).
Basically - you can use the following workflow calling CREOSON functions:
for each fileName in file : list *.prt
   file : open fileName
   interface : export type=STEP file = fileName (opt - filename = stepfileName)
Pretty simple thing to do.  Probably worth looking at the CREOPYSON version first.
Dave
MartinHanak
(To:Ed13)
