Cosmetic Thread Class Issue
PANNA_PANNA
Good morning,
I'm having a similar issue, the thread note that you are seeing is a note of a cosmetic thread,
In the holes made with standard hole
i can apply the note that i would from the .hol file but in the hole made with cosmetic thread i'm not able to understand from where it's taken and i can't edit.
Even if in the cosmetic hole thread i'm selecting the same library of the standard hole with the "right " note i'm not able to obtain the result this i want.
any suggestion?
Thanks!
Reference topic: https://community.ptc.com/t5/3D-Part-Assembly-Design/Cosmetic-Thread-Class-Issue-Creo-5-0/m-p/612900#M65730
2 REPLIES 2
Hi @PANNA_PANNA
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
What version of Creo are you using? Have you looked at the ISO.hol file like that post mentioned?
