Cosmetic thread
joe_c
Cosmetic thread
Folks
How would you hide the solid vertical lines on a cosmetic thread? Edge display/ Environment tangent edges/ layersdo not work.
Also, is there a way to change the dimension tolerance to display across instead of upper limits/lower limits? basically delete the upper limit superscript. say ø24 - 0.1. I dont know if isthe proper way. Someone here wants it this way but i have my reservations. Anyone uses this format?
thanks
Joe Cosme
Project Engineer
NLOS Artillery Div
Picatinny Arsenal, NJ 07806
Comm: 973.724.4791
mlocascio
(To:joe_c)
Easy answer? The cosmetic thread is typically a surface. In order to remove "the vertical lines" you would have to remove the surface too.
