Créo 2 - Cotation/Dimension - orientation du texte
ftaillandier
Hello, I would like to kwow how can i modify the CONFIG.PRO ----> to put dimension with text  "parallel to and above leader"  ??
Thank you.
Fabrice...
Bonjour,
Voici ce que j'ai :
9 REPLIES 9
Bonjour,
Voici ce que j'ai :
See if this post helps:
Re: How can I change how dimension lines appear?
Dale
this property is not set directly in config.pro. It is set in drawing setup file. config.pro contains drawing_setup_file option which points to drawing setup file.
MH
Martin Hanák
Hi and thank you Martin.
I copy the original file ( prodetail.dtl ) but sorry i don't know how i can edit it ....
if you have prodetail.dtl file, you can edit it in Notepad/Notepad++//Wordpad. Then in config.pro define drawing_setup_file option which points to prodetail.dtl (enter full path to file). In this situation when you create new drawing, Creo copies the contents of prodetail.dtl file into the drawing. Later if you want to change settings in existing drawing, you click File > Prepare > Drawing Properties and then in Detail Options you click change and modify what you want.
MH
Martin Hanák
Hy Martin,
thank you !!!!! it's ok now...
you're the best !!
Fab.
Bonjour Raphaël,
peux tu m'envoyer ton fichier prodetail.dtl   ???
merci.
Fabrice
Bonjour Fabrice,
Ci-joint mon fichier dtl "standard"
ok. merci bien.
