Create Balloon by Record - Not working
  • January 4, 2022
  • 4755 views
This functionality seems to have stopped working for me. Typical bulk items will not accept balloon creation, either for the stock simple circles nor custom split balloons.
There was a video posted as a solution to this awhile back from @bduncan , but I can't seem to get to it.
Creo 4 M100
Any help is appreciated.
you can add following special drawing option to your drawing:
update_drawing all
You have to enter this option manually in Creo dialog box. Do not save the drawing automatically. The above mentioned option can cause unexpected problems.
If this option resolves the problem then this means that your drawing is corrupted somehow. I suggest you to create new drawing.
Hello @PapasaurusPrime
If value all for the update_drawing entry is not wished (to avoid losing control of what is being fixed with this "all" value), and impacted repeat region attributed is set to No Duplicates, the update_drawing values 1144731 and 1820521 may be enough to fix this.
=> Refer to article 17253 for further technical details.
Serge Acquarone
Thank you for this Serge. Although it didn't work, it's very specific to my problem, and the hidden option will come in handy.
