Create a copy of an assembly in another assembly
ptc-5106202
I am trying to add two assemblies (a) and (b) into a third assembly (c). I only need some of the parts from (a) and (b) in (c). How can I copy (a) and (b) so that when I delete the part files I don't need it doesn't delete them in the original assemblies (a) and (b) as well?
4 REPLIES 4
Dale_Rosema
(To:ptc-5106202)
You could create a family table for assemblies A & B.
When you assembly them into part C, you could assemlbe the various sub assemblies of A & B.
C contains complete A and B
C1 contains A1 and B1
C2 contains A2 and B1 (or whatever combination)
For the family table you could have assemlby A be the complete assembly and A1 be the parts needed for the C1
This actually treats them as separate subassmelbies (which they are).
Dale
vmráz
(To:Dale_Rosema)
Second way is using simplified representations of your assemblies A+B. Than use thise two simplified rep in assembly C...
Check these web for Simplified Representation
Save-As has many options but please 1st understand well how Creo treats parts in memory.
Dale_Rosema
(To:TomD.inPDX)
Either way, becareful what your assembly constraints are so that if you delete a component (or don't assemble it in a family table) that it doesn't prohibit the parts that you require from assembling (or deletes that too) becasue a constraint is tied to the part removed.
