I would like know if is possible with modelcheck to create automaticly parameter "Commentaires" with type = string and designate in PDMLink.
Second step, is it possible to compare the file name (without extension) with the reference parameter (string type) and advise if they are a difference.
Thanks lot for your reply
Hello Benoît,
See the help for this setting in the start check file: Parameters.
Domingo posted the help collection here: ModelCHECK Help Topic Collection.pdf
You can create parameters, and check for for equalities to values that can contain wildcards etc. Plus you can check against a list. You can make a list right in the start file or have it read an external file. See help section "External Lists"
- Jim
