Creating Composite Datum Curves
jwilkerson
Hi Pros,
How do you create a composite datum curve?
I have two "sketch" curves and two datum curves that I want to make into a composite curve. I get that I need to select one of the curves and use edit > copy and edit > paste to create the composite curve. But when I try to do this the copy "dashboard" does not come up. I starts the window like it does when you create a regular datum curve or a sketch curve, depending on which one is selected when I do the copy, paste.
I did this a few months ago when I had some Mechanica training, but I cannot duplicate it today.
I am sure that I'm not holding my mouth right.
Jody
Hi Pros,
Found my own answer and yes I wasn't holding my mouth right. You have to select the curve and then select it again until it changes to a "fat" red line.
Makes no sense, but it works.
Jody
