I wish to create a dynamic text within a table cell that counts the numer of symbols on a drawing.
This would be used to update the number of revision triangles in a drawing.
1. How do I create dynamic text?
2. How do I code the text to count the number of symbols of a specific type?
Miguel
Miguel,
I think it is not possible to get number of symbols using standard Creo functionality.
Martin Hanak
Thanks Martin!
Beyond standard creo functionality, is there any add-ons you might recommend that might be able to facilitate this?
Miguel
Miguel,
I think you can contact your VAR. I hope they will be able to tell you who can develop a custom application with requested functionality for you.
Martin Hanak
Miguel,
you can count number of symbols in Drawing mode using the following procedure.
Martin Hanak
Yes. I am aware of that.
But when you do that, it counts all the symbols and does not distinguish between specific ones.
So my revision triangles are counted with my welding symbols.
So this does not serve to help me populate the number of revisions field.
thanks
Miguel
Miguel,
I tested Search funcionality with drawing symbols. I set the appropriate symbol name in Name field and Find Now returned the correct quantity.
If you can, please upload some example data. I can test searching them.
Martin Hanak
Ok great.
I'll look a bit further into it.
Miguel
