I am looking for a way to create Unit Basis (Rate of Change) on a Flatness. I tried applying it in Annotate with a Composite frame, but it gives me a message stating that the "Per Unit Basis is not Compatible with the Specified Characteristic symbol." There doesn't seem to be a direct way to apply Unit Basis to Form.
I am also looking for a way to change the Tolerance Standard to ASME. It looks like ANSI and ISO are allowed out of the box. How would I add the ASME standard?
Hi @jbrehmer,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
