Gurus,
WF 4.0 M060 & PDMLink 9.0 M010
We make our solid models and use shown dimension in our drawings. We also like to use shown or created dimensions in combination with other dimensions. Such as showing the counterbore dimeter and depth for a hole using &ad131 or &d43. This works great for our detail drawings. The issue is that our manufactoring engineers use our models to create shop/process drawings. These drawings use created dimensions so that the MEs do not accidently change the nominal design of the part. The issue that we are finding is that when they create a dimension on the drawing, the part is requested to be checked out into the workspace. We find if you choose not to check out the part and select continue, the changes will not always be saved or Windchill will create "new" parts in the workspace. This seems to happen if another person has checked out the part and has made an iteration change to the part.
We have searched around the forums and the googlenet. We have found that we can use this setting in config.pro (create_drawing_dims_only) but we would not like the design engineers since it prevents the early stated advantages. Using this setting you can not use the dimensions parametrically in the drawing details or in tables. It seems to be a one way communication flow from the model to the drawing. I am thinking about creating a config.pro file just for our MEs to use that has this setting in place. Before I do so, I am curious if anyone else has the similar issue and a better resolution to this.
James
