Friends,
Is there a way to print/SaveAs the sheets in an RS Designer design as
a text searchable Adobe Acrobat pdf file? There is no SaveAs option
for pdf, and when I print to the Windows Print Manager, and then
select the Acrobat printer, I get an Acrobat file with all graphics
and no text. I understand that there is an OCR option in Acrobat, but
I would like to export it with the embedded text, not fix it after the
fact. It is a requirement for our end customer, and I recall there
was a SaveAs option in Pro/DIAGRAM which saved as a searchable pdf.
I'm sure there is something obvious that I am doing wrong. We are
using RSD 6.0 M030 and Acrobat 8.0 Standard. Thanks in advance!
Akbar Husain PE
ahusain@estandard.com
