Creo 1.0 - Multiple model states in a drawing...
branden
I have a sheetmetal part that I need to show on a drawing in both flattened state, and bent state.
How do I save both states of the model to bring into the drawing? I cannot figure it out in Creo 1.0.
Any help would be greatly appreciated.
Thanks!
2 REPLIES 2
It appears that this can still be done with the family table (if you use them). Search help for "flat instance" and the first item returned describes the general process. I fumbled my way through it, and I say fumbled because the workflow is completely different and, as we are not using this version yet, I haven't learned where much is located in the U.I..
James
byork
(To:branden)
James and Branden,
You can use the config option "enable_flat_state" and set it to yes.
That will give you the option inside of the properties window to create the "flat state" like you could in Pro/E before.
[cid:image005.jpg@01CC5E48.95F528F0]
[cid:image006.jpg@01CC5E48.95F528F0]
Then you can add the instance to the drawing just like before.
Hope this helps a little with the workflow.
