Creo 2.0 - Part mass question
eheskett
I have an import part made up of surfaces so it has no volume.  I know the actual weight of the part but I don't know how to specify this in the parameters.  When I do a mass properties of the next assembly I need it to include this "weightless" component.  Can this be done with relations?
2 REPLIES 2
huggre
(To:eheskett)
Eric
Go to Model Properties and then change Mass Properties.
In the "Define Properties by" drop-down list select "Fully Assigned".
You may now manually specify Mass, Volume etc.
Hugo
eheskett
(To:huggre)
Thank you.  I will give this a try.
