Creo 2.0 Why does MBD dimensions sometimes fail to show when not selected in the detail tree?
rbast
In this case I added a round to a sheet metal wall using the round feature
(Model tab>Engineering>round). Moving over to the annotation tab I then
selected the round in the model tree and used ‘Show annotations’.  The dimension shows and I accept it.  The dimension is now in the detail tree and
is selected (highlighted).  When I click
away the dimension stays in the tree but disappears in the model space.  I can select the dimension in the tree and it
will show.  Deselect it and it hides in
model space again.  What is the cause of
this issue and how do I prevent it from happening again?
rbast
(To:rbast)
It was in error because of sections.  Applying new datum's and placing the dimensions on the new datums works.
kdirth
(To:rbast)
Is the annotation being automatically added to a layer that is hidden?
rbast
(To:rbast)
