hello, im look to see if someone has a weld symbols thats all inclusive with option for arrow side and other side at the same time staggeren and non staggered, combination flares etc etc but all inclusive in one weld symbol. thanks guys
im running into the situation where the arrow side and other side seymbols shows up with a long tale and just takes up entirely too much on the drawing, the shorter weld symbols fit great but do not give me the arrowside and other side options at the same time.
any help would be great.
thanks guys
Carlos
You might learn how to modify your own symbols. making comprehensive symbols is a lot of work. Some are easier to make on the fly and save them to a library.
i dont have the time or resources to get into that right now. i thought it would be much easier to ask for someone to upload a symbol, but i guess not.
i have some weld symbols i can use, they just take up too much realestate on the drawing, but i guess i have to make due with what i got.
Carlos
There is not a huge library out here in the community for "solutions".
Most often, weld symbols are easier to manage on the fly within the drawing.
There is no reason to store it outside the drawing but easy enough to copy from one drawing to the next.
The only symbol I needed to create was a comprehensive surface finish symbol.
You're welcome to download it from here: Comprehensive Surface Finish Symbol
