Creo 3.0 and windows 10 cloud - lockups
  • August 12, 2016
  • 8 replies
  • 3343 views
Hello community,
Of interest to you; after updating to windows 10.
Although I run Creo from the 'cloud' (non PTC cloud), I have had lock-ups every couple hours, which require full system reset, (no re-boot just reset), then re-load.
This happens when model/assembly would hi-light either from me directly, or accidentally as cursor passed over.
System generally slow.
I disabled the mis-named 'smart' filter and turned off hi-light to work around (very much slower). Lock-ups still occurred when I needed to hi-light.
Solution; Graphics driver already up to date, Java update, and Bop-Da-Dahhhh switched back to using Internet Explorer! rather than Microsoft Edge.
This cloud business being highly Internet intensive. Creo also seems to run faster/smoother. I am so happy again with my friend Creo.
Creo update to M100 which supports windows 10, not investigated.
Creo 3.0 M080
Windows 10, 64 bit
I5-4200M 2.5 Ghz 8 Gb ram Laptop
GeForce 820M video memory 2G
Your lock ups may be from the unsupported video card. GeForce cards are not supported.
Creo3 m060 and higher are supported on Windows 10.
Define what you mean by 'cloud'? I have run Wildfire/Creo from a server install for the past 6+ years. I would not consider that to be a 'cloud' install.
shanus1-VisitorAuthor
GeForce 820M, OpenGL 4.4
Ah yes Creo supports windows 10 since M060 ref; https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS219828&source=Bloop
Cloud; Company is on VOS (go.vospro.net) all our applications are through them, stored, backed-up.
Technically I run Creo on their system and hardware, where my graphics card is of no concern, it is all about the network connection.
Thanks for responding.
I disagree, your graphics card is still processing the image data locally.
After several iterations of toggling various graphics settings in config.pro,
The correct solution was to set config option - fast_highlight = NO
I still enable highlighting through SELECTION and config option - enable_face_preselection = NO
No effect from various display quality or fsaa.
Fishing helps!
