Creo 4.0
anewbauer
9-Granite
Creo 4.0
Hello All
Been working with Creo 4.0 and so far the flexible modeling that they have added is really nice.
It is comparable to  direct editing and the move face command in Solidworks.
However i noticed that when you have datum points on the geometry they do not update with the moved solids or surfaces.
Does anyone know if you can have them move with the (move with dragger) command?
thanks
Allen
Allen,
When moving face, Select Face > Add datum under "Move Curves and datums" and drag.
Thanks for the input.
