Creo 7 - Arrowhead Disappears when adding datum to GTOL
PD_10144284
2-Explorer
My left side arrowhead disappeared after I added datum C to that true position tolerance. How do I bring that arrowhead back?
2 REPLIES 2
StephenW
(To:PD_10144284)
@PD_10144284
Maybe, just maybe, if you select the dimension and then right mouse button and look for "show witness line"
It looks like the witness line is there so I don't thin this will work but that is what the arrow looks like when you erase one witness line.
@StephenW, thanks for your reply!
"Show witness line" didn't work because it was never erased.
If I remove Datum C though, the left side arrowhead shows back up:
Any other ideas?
