First and foremost creo lags so much on a brand new computer. Yes i have read the post where it says just write -g:win32_gdi and yes it fixed the problem with the lagging. It works crisp with that setting. But the model colour is all dark grey and unusable. And the fix to that is to remove -g:win32_gdi. Can i have a crisp program with correct colours and graphics at the same time?
The use of win32_gdi is to help diagnose the root cause of the issue. If as you have noted this option eliminates the behavior, then it suggests that the cause of the issue is a graphics driver problem. Is your hardware ISV certified to run Creo? If so, then you should have access to a GPU driver typically from your HW supplier that is certified for use with Creo Parametric. Find and install that driver and then test the performance again.
what graphic cards are installed in your computer?
