I have question if is possible in terminal table to use value with spaces.
Example:
| SET |
| PIN |
| DESCRIPTION |
| Receptical 2.8 JPT |
I would like to get values with spaces in tables.
Or is it only solution to use underscores instead of spaces?
Thanks for answers,
So
We are using Creo Schematics 4 F000 and have spaces in a number of fields of our terminator table.
| SET | SET | SET | SET |
| PIN | PIN | PIN | PIN |
| wire_gauge_range | notes | Crimp_to | material |
| 22-20 / 0.35-0.50 | Orange Seal | SEAL & WIRE |
TIN BRASS |
The field names don't have spaces but we use them in the data.
It may depend on what version you have.
TIN BRASS |
