Creo Distributed Batch to run a Mapkey to export dxf from a drawing that has 10 or more pages
Creo Parametric 8.0.6
I've created a mapkey to export dxf file and save drawing/part parameters then use vbscript to rename the dxf file, the mapkey works great in Creo but when i use distrubuted batch to export dxf using this mapkey it will only export the first page, is there a way to loop this for all pages in a drawing?
TTD
<TTD version="1.0" created_by="PTC">
<DESCRIPTION>Run a mapkey defined in a config.pro</DESCRIPTION>
<GROUP>Misc</GROUP>
<DETAILS>Will be run on any file type; user is responsible for choosing types that mapkey will operate on correctly.</DETAILS>
<SERVICE name="dbatchs"/>
<FILTER_FILE_TYPES type=".drw"/>
<!-- Replace "F1" with chosen mapkey when customizing file -->
<TKFUNC func="ProMapkeyRun" mapkey_key_sequence="dxfdet">
<save_model>false</save_model>
</TKFUNC>
</TTD>
