Creo Drawings - Arrow Tail Length
Daves1
I am trying to figure out how to change the length of the tails on dimension arrows in Creo 2.0. I found how to change the size of the arrows, but the tail lengths are still very long.
Any help you can provide will be appreciated.
Dale_Rosema
(To:Daves1)
In the config.pro for drawings these might help:
dim_leader_length - set length of dimension leader line when leader arrows are outside of witness lines.
dim_text_gap - controls distance between dimension text and dimension leader line and represents the ratio between gap size and text height. For diameter dimensions, it controls the extension of an elbow beyond the text if "text_orientation" is "parallel_diam_horiz".
Hope this helps. Dale
5 REPLIES 5
Dale_Rosema
(To:Daves1)
Dale, Thanks a million! I really appreciate it!
In WF4.0 you could drag the dimension to change the leader length dynamically. How do you do this in Creo?
Ryan,
Select dimension > Press SHIFT > Drag Cursor to change leader length.
Thank you. I wish there was a way around using the shift button for this, the alt button to change text in the title block, and other annoying extra buttons that weren't required in WF4.
