Creo Elements Missing Assembly Components
pstephens
Hello All,
We have a group that create simplified truck models from template models.
They copy the templates to create their required specific chassis models, then select values in a layout which drive parameters that resume suppressed components in the chassis assembly, to build specific truck configurations.
Since a week or so ago, during regeneration of parameter values into the assembly to resume required suppressed models, some users are getting the error that the models are missing and are having to manually add them to their workspaces.
Other users, with the exact same Windchill group permissions, same config.pro settings are not having that problem, the missing models are obtained from commonspace as required and resumed automatically during regeneration.
We have even tried to manually force it to work by setting dm_search_primary_server to yes, but to no avail.
Same config settings, members of same Windchill groups, same Windchill group permissions, different results, only started a week and a bit ago.
We have not changed anything system wise at this end during this timeframe.
Any theories to share on what might be happening here, we are at a loss to work it out?
Creo Elements Pro, M130
PDMLink 10.0, M030
TIA
Paul Stephens
Kenworth Trucks Australia
0 REPLIES 0
