Creo Elements / Pro (WF5) Drawing
wfalco
All,
Opened a drawing for the first time using Creo Elements / Pro (WF5)
Drawing.
Can't manipulate dims and notes.
I feel like I am missing something dumb.
Anyone?
WayneF
wfalco
(To:wfalco)
Thanks Kevin Pietila. Select annotate tab. Doh. Feels like and Adobe
product now.
They fixed that in the Creo releases. One thing that helps - use your Alt key when you're in the Layout or Table tabs and you can select and manipulate annotations - only shortcoming is you can't get the Properties to show up in the RMB menus
Mike Brattoli
Moen Incorporated
Global Product Development Process Management
Administrator - PLM
Ext: 2916
StephenW
(To:wfalco)
Unfortunately, WF 5 was the beginning of the ribbon. It was harder to work with. Creo 2 did improve the tabs functionality made it not so hard to do drawings.
WF 5 forces you to be in the correct tab for everything where-as Creo 2 allows several actions without tab selection.
There is improvement coming for you (in Creo 2) but you'll feel like you paid your dues with WF5.
