Creo Harness Package not showing Center line for wires
When I switch over to centerline mode in the harness package the center lines are not shown, however when I hover over them they highlight... any suggestions how to get them to show? I cant right click and edit to add a location to the segment in this manor, which is frustrating. I used to be able to see them at one point.
When using show as thick cable it shows the cable without issue.
I have found it to be a new config.pro setting I added "shade_with" I had set to no
