Creo Options modeler Question .
Narendarv
Hi i am using creo options modeler to build a configuration assembly , the assembly has multiple modules and each modules has  a few small subassemblies,
But the subassmblies repeat in multiple modules at different locations in the assembly and these  are assembled in various angle.
But i am not able to bulild the configuration assemble, when the parts  or subassemblies are repeating, i have tried replacing with copies, but then the end Bill of material gets affected, any help will be appreciated.
Thanks in advance.
Naren
I was able to solve this.....
Hey Narendar,
That's great that you were able to find the solution.  Would you mind sharing it here and also marking the thread as answered.
Amit
